May 4th, 2024, 11:00pm
How to measure the Q factor of a low pass filter in Cadence? (Read 959 times)
josvlsi
Apr 03rd, 2018, 12:02am
In cadence after plotting the AC gain and phase of a given filter, how can we determine the Q factor of the given filter??
I tried doing pz analysis but that displays a number of Q factors for different poles and zeroes. How can we determine the Q factor of any given filter in Cadence?
buddypoor
Bremen, Germany
Re: How to measure the Q factor of a low pass filter in Cadence?
Reply #1 - Apr 3rd, 2018, 1:07am
I suppose you are referring to the Q factor Q=Qp of a second-order lowpass, correct?
Well - it`s very simple:
At the pole frequency wp the magnitude of the transfer function is A=Ao*Qp (Ao=Gain at DC).
The pole frequency wp can be identified very quickly: It is the frequency where the phase shift is exactly -90 deg.
josvlsi
Reply #2 - Apr 3rd, 2018, 2:18am
Yes, it is a second order low pass filter.
how did you get A=Ao*Qp (Ao=Gain at DC). ?
Jacki
Reply #3 - Apr 10th, 2018, 11:41pm
Hi buddypoor,
  Is the pole frequency exactly at -90 deg or -45 deg?
josvlsi
Reply #4 - Apr 11th, 2018, 12:04am
The pole frequency can take any value depending on the filter design. I want to know how can we find the Q factor for any active second order filter simulated in Cadence
