Jul 23rd, 2024, 1:13pm
LDMOS voltage tolerance (Read 1432 times)
neoflash
Mixed-Signal
Designer
Apr 07th, 2018, 9:36pm
In deep sub-micron process, usually LDMOS can be used for higher voltage tolerance.
With drain extension, it is understood that Vds tolerance can be increased.
However, why Vgd tolerance is also increased?
For example, in 40nm process 3.3v oxide, LDMOS Vgd can tolerate 5V?
I don't understand why Vgd (involving oxide) can be increased when there is no current?
Jacki
Re: LDMOS voltage tolerance
Reply #1 - Apr 10th, 2018, 11:35pm
I have the similar question, for my experience, with the same IO transistor, when I increase the channel length, the gate voltage can be increased as well, for example from 1.8V to 3.3V. But the gate oxide thickness seems not increase.
