Sep 25th, 2026, 10:14pm
VerilogA model for Current Monitoring (Read 4026 times)
sanforyou
May 29th, 2018, 9:43am
I want to write a VerilogA model which monitors input current and prints a message if it is above certain level. I also want output to be same as input current.
I wrote a model and it works but throws out below error when I add a line for output current to be equal to input. Any suggestions what I'm doing wrong here?
`include "constants.vams"
`include "disciplines.vams"
module CurrentMonitor_VlogA(Iin,Iout);
input Iin;
output Iout;
electrical Iin,Iout;
real Ivalue;
parameter real IT2Limit=1m;
analog begin
	Ivalue=I(Iin);
	I(Iout)<+ -I(Iin);
	if (Ivalue>=IT2Limit)
		$strobe("WARNING:Value of current at node Iin has exceeded %g at %m, Iin=%g at simulation time t=%e",IT2Limit,Ivalue,$abstime);
	else
		$strobe("Current at node Iin=%g, simulation time=%e",Ivalue,$abstime);
Here is the error message:
   ERROR (SPECTRE-16384): Signal V(Iout) = -732.434 GV exceeds the blowup limit for the quantity `V' which is (1 GV). It is likely that the circuit is unstable. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
« Last Edit: May 29th, 2018, 1:46pm by sanforyou »
Re: VerilogA model for Current Monitoring
Reply #1 - May 29th, 2018, 10:38pm
This was answered in this thread: https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/38857...
The output of the current-controlled source was left open circuit, and then I proposed implementing it as a zero-volt source instead of a current controlled source.
sanforyou
Reply #2 - May 30th, 2018, 8:31am
Thanks Andrew.
