Dec 7th, 2025, 11:31am
Broadband Circuit Transmission Line Modeling in  Spectre (Read 3697 times)
repah
Sep 09th, 2018, 6:39pm
I am designing broadband circuits in Cadence Virtuoso/Spectre and modeling the transmission lines in an EM solver and importing the S Parameters.
My circuits are broadband over - say 0-40 GHz.
My question - can I use the S Parameters from the EM solver (touchstone) using an n port in Virtuoso/Spectre and run transient analysis in Cadence Virtuoso/Spectre to see - say eye diagrams ?
What issues will I face ?  Can I use the n port for transient analysis ?
Thank you.
deba
Re: Broadband Circuit Transmission Line Modeling in  Spectre
Reply #1 - Sep 14th, 2018, 6:26am
Yes you can use n-port for transient analysis. Look out for interpolation methods, rational order etc. Last I heard there is a new method called BBSPICE(broad band spice) available for interpolation.
Frank Wiedmann
Munich, Germany
Reply #2 - Sep 17th, 2018, 2:27am
Take a look at https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionN.... In most cases, the BBSPICE method works best.
