Sep 17th, 2024, 7:30am
Clocking and Timing of SC Sigma Delta Modulator (Read 2293 times)
repah
Nov 12th, 2018, 8:06pm
Please see attached picture.
What is V in the clocking - ie. 2d/v and what is the timing of the reset clock ? When is the reset clock set, how long and why ?
Is is reset every OSR clock cycles ? Also isnt just setting an ideal capacitor with initial condition zero in simulation the same as setting a reset signal ?
Thank you.
polyam
Re: Clocking and Timing of SC Sigma Delta Modulator
Reply #1 - Nov 13th, 2018, 3:58pm
V is the output of the delta-sigma and it needs to be fed back to the input to close the delta-sigma loop.
There are two main reasons to reset a delta-sigma modulator.
1- To lock up the ADC when the internal states get saturated.
2- To serve as a resettable ADC (well-known as incremental ADCs). In the incremental mode, the delta-sigma gets reset every OSR cycle and the ADC starts digitizing the next channel.
It's always nice to have reset signal even though the ADC is not going to be used in an Incremental mode. Otherwise, you need to play with supply voltage to lock up the ADC Grin!!!
Tnx
repah
Reply #2 - Nov 13th, 2018, 4:01pm
Okay, thank you.
Just to be clear, in incremental mode - the reset signal is sent every OSR cycles and how long is it set for ?
Is there a good reference on this - none of the existing sigma delta texts explain this very well.
Thank you.
polyam
Reply #3 - Nov 13th, 2018, 4:11pm
It's like this: you reset ADC (rst=1) and then reset is off. Wait for OSR cycle and then reset.
Have a look at "A low-power 22-bit incremental ADC"
polyam
Reply #4 - Nov 13th, 2018, 4:15pm
Also
Theory and applications of incremental /spl Delta//spl Sigma/ converters
repah
Reply #5 - Nov 13th, 2018, 4:57pm
Thanks.
How about regular, non incremental Sigma Delta ADCs like this one:
When does that reset get set - thats a second order discrete time sigma delta ADC.
Thank you.
