Spectre has an "AHDL Linter". This can be turned on in ADE via Simulation->Options->Analog and is on the Miscellaneous tab. From the command line it's the -ahdllint option.
There are some static checks which will then appear in the normal simulator output log, and then some checks during simulation for potential performance issues or improvements (in ADE the Linter log can be shown from the Simulation menu).
