Feb 15th, 2026, 8:46am
Passing in a bias point for a verilogA model (Read 1664 times)
kevinvinv
Mar 14th, 2019, 1:49pm
OK,  thanks for taking a look at this post  :)
I have a verilogA model that contains some laplace_nd() function calls.
Some of the coefficients for the numerator and denominator of the laplace function need to be calculated at run time so I pass them into the block as voltages.
These voltages have zero AC component themselves but their DC component is used to set various pole and zero locations using the laplace_nd function.
It doesn't seem to be working as I had hoped and I am thinking rather than having the voltage enter the verilogA block as the bias point number I wish, that instead it is coming in as the AC value of zero.
Is this making sense at all?   I can post the model if anyone has the patience to look further.
Bottom line is...   am I able to send in a number calculated at run time - as a voltage- into my verilogA block and into the terms of a laplace_nd()
function.
ps-  I do understand the array variable requriement of laplace_nd()  (I think)  :)
THANK YOU
__________________
Kevin
kevinvinv
Re: Passing in a bias point for a verilogA model
Reply #1 - Mar 14th, 2019, 2:58pm
OK I think the problem was that I had a fractional coef for the highest power of s and it seems that Spectre doesn't like that....   silly spectre...  so it set it to "zero" instead.
I factored that initial coef out so that I could specify it as '1' and then multipled it back in later.
hoops...  :)
Thanks.
__________________
Kevin
