Aug 14th, 2024, 3:01pm
current gain temperature coefficient of BJT. (Read 970 times)
Jacki
Apr 08th, 2019, 12:21am
   I forget the bipolar transistor characteristics, and cannot find any good references. Anybody can help me about the current gain temperature coefficient of bipolar transistor? I read some device principles, and it looks the current gain temperature dependent effect mainly decided by the base of the transistor, and it has negative temperature coefficient. Any comments on it or good reference?
   Thank you.
Jacki
Re: current gain temperature coefficient of BJT.
Reply #1 - Apr 12th, 2019, 7:28am
Solved, actually it is quite clear if we look at Vbe = VT/n * ln(Ic/Is), if we consider Ic/Is as the current gain, and Vbe has the CTAT characteristic, we can clearly get Ic/Is is a CTAT.
