Oct 6th, 2024, 12:30am
question on pnoise sim theory (Read 1985 times)
dog1
Apr 09th, 2019, 12:35pm
Hello all,
I have a question about the pnoise simulation.
I understand that in frequency domain, the switching system should translate noise in the following way:
cross correlate the noise source spectra with the model of the system large signal behavior (eg. square or sin signal in a mixer)
However, I read in the manuel that the pnoise is actually "a time-average of the noise at the output is computed as a spectral density versus frequency". This I could not understand, because it looks to me that "the model of the system large signal behavior" as mentioned previously is different from "a time-average of the system transfer function at each bias point in a period".
For example, for a simple mixer, "the model of the system large signal behavior" could be a square wave, while at each time point, this simple model results in a transfer with infinite BW, thus the "time-averaged" version also having infinite BW.
I don't know where goes wrong. Could anybody help me? Thanks.
Re: question on pnoise sim theory
Reply #1 - Apr 11th, 2019, 12:41pm
SpectreRF performs a detailed noise analysis including all correlations, and then presents the time-average of the noise. So the time-averaging only occurs after the noise leaves the circuit and is being processed for display.
This is very analogous to the case where you are observing the noise of a circuit with a spectrum analyzer. The circuit processes the noise including the effect of all correlations, and the result is observed by the spectrum analyzer when then computes the time-average of the noise before displaying it.
dog1
Reply #2 - Apr 12th, 2019, 2:19am
Hello Ken,
Thanks very much for your reply. Now it is clear for me:)
Best regards,
Chen
