Sep 19th, 2026, 2:50am
Value of DC block capacitor in LNA (Read 1875 times)
engrvip
Jun 19th, 2019, 9:17pm
Hi
I am designing a 2GHz common gate CMOS lna and need to add DC block capacitor at its input i.e. source of input MOS.
I have come to know that value of this cap should be approx. 2Ohm to avoid adding high impedance in signal path at desired frequency which if calculated using formula 2-Ω= 1/ωC at 2GHz; value for dc block cap comes out to be 39.8pF.
Is this the right way to calculate value for DC block cap in LNA rfic ? What if I used smaller value say 5 or 10pF. Will it disturb my input matching since I have dc biased input CG MOS such that it gives gm=20mS resulting in 50-Ohm impedance at its source and LNA input.
Vipul
Horror Vacui
Dresden, Germany
Re: Value of DC block capacitor in LNA
Reply #1 - Jul 24th, 2019, 12:21am
The DC block is in series with your input, thus its impedance adds to the input impedance of your circuit w/o the cap.
Do I miss something? It seems way too simple.
