Jul 2nd, 2025, 11:30pm
Phase noise measurement using E5052B (Read 1740 times)
deba
Aug 19th, 2019, 9:32am
Hi All,
E5052B from Keysight uses "PLL method" to measure phase noise. I am measuring the phase noise of a 100 MHz square wave clock using this instrument. The effective offset range of the instrument is mentioned as 10 MHz for a 100 MHz clock, roughly 10% of the input clock frequency.
I am interested in phase noise beyond 10 MHz. What does the instrument measures at these offset frequencies? Does it show amplitude modulation(AM) sidebands along with phase modulation(PM) sidebands?
Horror Vacui
Dresden, Germany
Re: Phase noise measurement using E5052B
Reply #1 - Sep 18th, 2019, 5:01am
10MHz away from the 100MHz signal you should see the noise floor...
