You can't use SystemVerilog with Spectre (similarly you can't use Verilog, VHDL, or Verilog-AMS with spectre either, since it requires an event-driven simulator). You can use SystemVerilog with AMS Designer though since that's a mixed-signal simulator, and really there's nothing special you need to do for this. If using ADE, you'd create SystemVerilog textual views, or you can reference external files with a .sv suffix - it just works.
