Jul 15th, 2024, 11:25pm
Proper modelling of a current source in verilogAMS. (Read 2298 times)
edstrom
Nov 28th, 2019, 3:29am
I am struggling with modelling a current source in verilogAMS.
An ideal current source with a load would be
      I(vdd, ibias)      <+  20e-6;
for a current pin ibias.
The problem with convergence comes with this implementation when the pin ibias is unloaded. The simulator will drive that current without any load, resulting in a very large voltage, resulting in a zero diagonal unsolvable matrix.
What would be necessary, is to model the output impedance properly.
I have tried to short the output through a large resistor.
      V(ibias,vss) <+I(ibias,vss)*100e6;
But the above statement still drives the current to the output ibias, generating convergence issues.
What would be the proper way to model this?
Re: Proper modelling of a current source in verilogAMS.
Reply #1 - Nov 29th, 2019, 10:58am
You can add a resistive clamp:
I(vdd,ibias) <+ 20u;
if (V(vdd,ibias) < 0)
    I(vdd,ibias) <= V(vdd,ibias)/1k;
Not sure that code is right. I am in an airport and cannot try it. Bascially, it is designed to add a 1k resistor connected to Vdd when ibias goes above Vdd.
edstrom
Reply #2 - Dec 2nd, 2019, 11:39pm
Thanks Ken,
I tried your code snippet with some minor syntax changes. And i still experience convergence issues in the node ibias.
I to me, it makes sense. Because i will still drive a current from supply to a floating node
Horror Vacui
Dresden, Germany
Reply #3 - Jun 28th, 2021, 1:20am
I've made the current a linear function of the voltage below a voltage threshold. Basically it is a resistor below the threshold and a current source above that. The current source will therefore pull the node to simply towards ground. It also mimics the reduced output resistance of current sources at low output voltages.
I do not got the code at hand, but it is simple to implement.
