Aug 14th, 2024, 8:31am
variation of parasitic resistance in vertical PNP devices built in CMOS tech (Read 1397 times)
vivkr
Jun 17th, 2020, 2:12am
Hello All,
I would like to understand the behavior of parasitic resistors in vertical PNP devices manufactured in the leading-edge CMOS processes.
The key parasitics are emitter and base (including base spreading) resistances.
The device model provided by the foundry has lumped both these into 1 single term, namely, the emitter resistance and set this to a constant number.
Given that the precision of my circuits is primarily limited by these, I would like to understand if they are truly relatively constant (say within +/- 20%) over process and temperature or if they vary wildly (say +/- 100% or so). If the former, then I could design for the nominal values of these parameters and be done. If the latter, then much more expensive multi-point calibration would be needed, which would be prohibitive.
Of course, one could get around the issues by biasing the devices at very low current densities (say 1/10th of what I am using), but that would make for a very inefficient design.
Thanks for your hints and comments.
Vivek
Tako
Re: variation of parasitic resistance in vertical PNP devices built in CMOS tech
Reply #1 - Jul 2nd, 2020, 4:17am
You should ask foundry directly. Usually, when working on a given technology, there is a person from the foundry that helps, e.g. application engineer. This person has access to more documentation that is provided with PDK.
I have never considered the problem described by you. I used vertical PNP transistors in CMOS technologies in bandgaps.
