Hudson
I am using verilog to model VCO with phase noise.
The VCO frequency is the summation of f0 + Kvco*Vcont + white_noise and I calculate the phase with the idtmod function.
" wn1 = 2*pow(Fos,2)*pow(10,(phasenoise/10)); V(vn)<+white_noise(wn1, "wpn_osc"); freq = (V(in) - vmin)*(fmax - fmin) / (vmax - vmin) + fmin + V(vn); phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
V(out) <+ va*sin(phase); " However, the phase noise has 40dB/dec roll-off in Pnoise simulation, which supposedly should be 20dB/dec. I also check that vn is white indeed. Then I did an experiment to directly add white noise to the phase, the output phase noise turns out to be 20dB/dec roll-off now. I do not know where the problem could be.
The full code is attached below
module vco0 (out, in , vn);
input in; voltage in; // input terminal output out; voltage out; // output terminal output vn; voltage vn; parameter real vmin=0; // input voltage that corresponds to minimum output frequency parameter real vmax=vmin+1 from (vmin:inf); // input voltage that corresponds to maximum output frequency parameter real fmin=1 from (0:inf); // minimum output frequency parameter real fmax=2*fmin from (fmin:inf); // maximum output frequency parameter real va=1; // amplitude
parameter real Fos = 1M;// from (0:inf); // offset frequency at which phase noise is given parameter real phasenoise = -120 from [-400:inf); // phase noise level
real wn1; // noise sources real freq, phase; integer n;
//voltage vn;
analog begin // compute the freq from the input voltage wn1 = 2*pow(Fos,2)*pow(10,(phasenoise/10)); V(vn)<+white_noise(wn1, "wpn_osc"); freq = (V(in) - vmin)*(fmax - fmin) / (vmax - vmin) + fmin + V(vn);
// bound the frequency (this is optional) // if (freq > fmax) freq = fmax; // if (freq < fmin) freq = fmin;
// bound the time step to assure no cycles are skipped $bound_step(0.1/freq);
// phase is the integral of the freq modulo 2 pi phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
V(out) <+ va*sin(phase); end endmodule
