Aug 14th, 2024, 11:00am
Switched capacitor stb simulation issue (Read 408 times)
iVenky
Aug 30th, 2020, 9:50am
I am trying to run stability sims for a switched capacitor op-amp circuit as shown.
I tried both ac and tran stb (not evaluated pstb yet).
I observe that in some corners, the frequency spectrum @ low frequencies (<10kHz) has weird issues.
Do you know what is causing this and how to solve this?
I tried enabling dc pivot check and pivot. Doesn't solve the issue. Also tried placing a 1G resistance parallel to C2 to provide dc feedback path; doesn't solve the problem either.
iVenky
Re: Switched capacitor stb simulation issue
Reply #1 - Sep 8th, 2020, 6:01pm
Any suggestions would be greatly appreciated.
Thanks Smiley
Reply #2 - Sep 8th, 2020, 7:55pm
There is not really enough information to go on.  Two issues that you should resolve are:
Quote:
ac and tran stb
Not sure what what that means. If you are using AC analysis, you should stop. To measure loop gain and stability you should be using the stb analysis.  As far as I know there is no tran stb analysis, so you should describe what you mean by that.
That is just to vague to allow me to offer any help.
And what are the two curves in the graph.
iVenky
Reply #3 - Sep 8th, 2020, 11:50pm
Sorry, if I wasn't clear before.
First, I just did stb analysis by placing a 1G feedback resistance to make the DC converge.
Second, I ran transient simulation and then ran stb (By enabling prevoppoint in the STATE-FILE PARAMETERS options window). This runs stb using the small signal parameters available at the tran end time I guess, right?
What do you think is a good way to simulate stb for a switched capacitor network like the one shown above? I tried pstb but I think pstb works well when phi1 and phi2 circuits are same (like in chopping or switched cap cmfb), right? Does it work well with the circuit shown above? Also, it's an integrator (not an amplifier) so obtaining periodic operating point is not that straightforward.
Thank you very much for your reply!
« Last Edit: Sep 9th, 2020, 2:03pm by iVenky »
Reply #4 - Sep 11th, 2020, 4:12pm
You should use pstb analysis as it is the most realistic.  You can use a 'frozen' AC analysis for an extra check if you like to give yourself more confidence, but it should not be at the expense of a pstb analysis. With the pstb analysis you are testing your circuit in the same way it will be used, whereas trying to us AC analysis creates an artificial situation that does not really match the way the circuit works.
It is also a good idea to run simple transient.  Normal stb analysis does not cover extreme situations, such as when the circuit is seeing a rapid step on its input which would cause the circuit to go into slew-rate limiting. Slew rate limiting is often a source of large-signal instability. I don't think this particular circuit is really subject to large-signal stability issues, but it is always good to check.  To check large-signal stability you apply large steps that change very rapidly. It is good to also set maxstep to a small value. Then look for ringing that is unexpected or excessive.
iVenky
Reply #5 - Sep 11th, 2020, 6:33pm
Hi Ken,
Thanks so much for your reply. I appreciate your time. What's "frozen" ac analysis?
Also, I am not sure of pss converging for an integrator when I try to do pstb analysis. I have seen documents online for running pstb for switched capacitor amplifier but not for a switched capacitor integrator.
Reply #6 - Sep 12th, 2020, 3:18am
An AC analysis is 'frozen' in this situation because it is applied at a fixed operating point, meaning that the clocks are frozen.
Yes, open loop integrators are always problematic, and are never used in practice. It is always better to make your test circuits as close to the real circuit as possible. Some times that is hard with clocked integrators because PSS analysis requires the circuit be periodic, but when you include the rest of the circuit you end up with a system that is not periodic.  None the less, you have to try to get as close to the real application as you can.
iVenky
Reply #7 - Sep 14th, 2020, 11:10am
Hi Ken,
Thanks for the reply. You mean like if this is used in an SDM, then I should include the entire SDM (or an equivalent model) so that it converges? Is that what you mean?
Reply #8 - Sep 14th, 2020, 10:33pm
No, see that is the rub. You cannot simulate a ΔΣ modulator because it does not have a periodic operating point.
In other words, you want to simulate the circuit within a representative environment so your results are representative, but sometimes you cannot. This is why you added the large resistors around the integrator. Those resistors are not represenative, but you need to something so the circuit has  a fixed operating point. The trick is to come up with a test circuit that allows you to simulate what you need while also being representative of the actual circuit.
Unfortunately, I have no recommendation.
