Sep 30th, 2026, 12:36am
Loaded quality factor of voltage control oscillator (Read 1752 times)
transign
Nov 27th, 2020, 10:53pm
How can I calculate in virtuoso the loaded quality factor of the VCO's main tank? Is there a specific test bench that I could use? Should I add only the parasitics of active devices?
Thanks a lot!
Horror Vacui
Dresden, Germany
Re: Loaded quality factor of voltage control oscillator
Reply #1 - Mar 27th, 2021, 4:30am
It requires the presence of the active devices -- like cross-coupled pair, or the amp in Colplitts - in its working condition. Therefore the circuit has to oscillate during the measurement1, which makes things complicated. I can think of multiple ways how to approach this problem, but probably the simplest is to run a PSS & PAC analysis.
Add a PAC current source in parallel with your tank. Sweep the injection frequency and measure the voltage across the tank
a) amplitude (Q= one-sided relative 3dB bandwidth)
b) phase change (Q=d(phi)/d(omega) omega_0/2)
1 Yes, I am using the phrase measurement even though the desired information is obtained by simulation and not with an instrument.
