Oct 10th, 2026, 6:17pm
Machine-Learning-based-Behavioral Modelling (Read 2334 times)
rhanna
Apr 19th, 2021, 5:33am
I need your help in debugging/tips to debug a Verilog-A module that I created based on the training of a Recurrent Neural Network (RNN).
The model is supposed to solve the non-linear differential system of equations coming from the RNN representation.
I will summarize everything in steps so that it will be easier to discuss it afterward.
1. I created a testbench for a chain of inverters and got the data (Vin,Iout) in .csv format after interpolation to a timestep=1e-9 s.
Attached testbench: https://drive.google.com/file/d/1n5uyi9_nTurEUgIai_yb0RWwVqGcYBIx/view?usp=shari...
and sample of Iout: https://drive.google.com/file/d/1APHkSRnFl5gxAFEDcvrW81Ygpvv7yMO5/view?usp=shari...
and training_data.csv: https://drive.google.com/file/d/1iKuxfxAz4b-mrt8UOs0gPqNqQfSwCnre/view?usp=shari...
2.Train/test datasets are pre-processed (scaled/normalized/standardized ...) to fit the RNN model used.
After tuning model parameters, it’s tested against unseen stimuli.
Attached learning curves: https://drive.google.com/file/d/1iF3D_tp4-F8p6B3sVirlBFtKVEoFMdUk/view?usp=shari...
RNN prediction: https://drive.google.com/file/d/1ufzQZsS19DvamE_oCMx9N6YZoM43tYTD/view?usp=shari...
and parameters matrices: https://drive.google.com/file/d/1eXxqaCrzyDqMTLY8N0_7Mp8-7QM1GkNP/view?usp=shari...
3. The parameter arrays are flattened to be used as 1-D vectors in the Verilog-A module (since multi-D is not allowed in Verilog-A)
Below, you will find a listing of my code which is basically using Spectre to solve the continuous non-linear system of equations of the RNN model.
code: https://drive.google.com/file/d/1zbWbgu4UApWolGYfJDxRuryDGtLgmFV1/view?usp=shari...
*** attached summary for the equations and the equivalent circuit of the model.
https://drive.google.com/file/d/1oHXT9a7a_cxw1xfquPQ-Aiv-q2njpI7E/view?usp=shari...
4. results after compiling and running the simulation look like that:
https://drive.google.com/file/d/1wm4wRaL_BK_j0iIwpdDx5-WbwmspQ7h4/view?usp=shari...
which is not really good! I changed alpha to consider different simulation steps but this is the best result.
Sorry for the long post and the many links and thanks in advance to your time.
