Jul 2nd, 2025, 4:50am
Questions on Sub-1 Volt OTA (Read 2359 times)
blue111
Jun 18th, 2021, 3:05am
Could anyone explain on "Obviously, the compensation capacitance CC does not connect Drain to Gate directly around output transistor M10. It takes a path through cascode device M6, in order to avoid a positive zero. " ?
Re: Questions on Sub-1 Volt OTA
Reply #1 - Jun 18th, 2021, 12:53pm
The desired effect of the compensation capacitor is to feed back some of the output signal back into an earlier stage.  However signals can flow both ways.  As the gain of the second stage drops at high frequencies, the signal at the left side of the capacitor can be larger than that on the right side. As a result, signal flow reverses and now the output is driven more by the compensation capacitor than the output stage.  This has two effects.  First, the gain levels off, which creates a zero as can be seen by examining the magnitude in a Bode plot.  Second, by bypassing the output stage, which is inverting, the sign of the signal reverses.  This creates an additional 90 degrees of phase shift.  In effect, has the look of a zero if you examine the magnitude of the gain versus frequency, but it has the look of a pole if you examine the phase.  In reality this is a right-hand plane zero (or RHPZ or positive zero).
To increase the frequency of the RHPZ so that it does not interfere with the stability of the loop, the designer has connected the compensation capacitor to a low-impedance node.  The signal level will be relatively small there, reducing the effect of the feed-forward path through the capacitor.  This will substantially raise the frequency of the RHPZ to the point where it is well beyond the unity gain frequency.  With this modification, the RHPZ no longer degrades the stability of a loop built with the OTA.
For more, see https://www.allaboutcircuits.com/technical-articles/the-right-half-plane-zero-an...
blue111
Reply #2 - Jun 19th, 2021, 2:40am
Someone told me that the circuit is using Ahuja compensation
However, I am not sure how it works
blue111
Reply #3 - Jun 20th, 2021, 1:29am
For those interested in Ahuja compensation, Baker's uses "indirect compensation" in his book : CMOS: Circuit Design, Layout, and Simulation , see page 813, 814 and 815
@kundert
As for equation 12 inside https://www.allaboutcircuits.com/technical-articles/pole-splitting-and-miller-fr... ,  I do not understand what the sentence downshift ω10 → ω1 must be accompanied by an upshift ω20→ω2. is actually trying to convey.  Why there is a guaranteed frequency downshift for the dominant pole, ω1 after adding miller capacitance ?
blue111
Reply #4 - Jun 20th, 2021, 6:24pm
I got it now.  It is due to dominant pole created out of the miller capacitance which generalizes to pole splitting effect as described by equation 12.
By the way, I created an actual mosfet circuitry implementation.
However, the transient analysis result look wrong.
A Kumar R
India
Reply #5 - Nov 9th, 2021, 2:53am
Ken,
Why did you say "As the gain of the second stage drops at high frequencies, the signal at the left side of the capacitor can be larger than that on the right side"....i think that by the time second-stage gain dropped, the first stage gain would have dropped a lot because the gain roll-off started earlier in frequency because it must be the dominant pole?. This means that signal on the left-side of the cap can never be larger than on the right-side.
Please clarify.
Anil
