Dec 17th, 2025, 12:46am
Phase Noise through the NTF of VCO (Read 2703 times)
subtr
Analog Enthusiast
India
Oct 21st, 2021, 7:35am
Assuming that I have a PSD of random noise on Vcontrol of VCO as discrete points from the simulator, eg. 50 points per decade. Now I have to simply find the phase noise at the output of the VCO. Do I :
A. assume the NTF is Kvco/f, do dot product of PSD and square(Kvco/f) at the corresponding frequency points?
                                                              OR
B. Now that the points are discrete, I assume each bin value is a sinusoid, convert the rms to peak by sqrt(2) and then get the USB/LSB as half the value and then dot product by square(Kvco/f) at the corresponding frequency points?
A and B differ by a scaling factor due to the sinusoid assumption.
Subtr
smlogan
Boston, MA
Re: Phase Noise through the NTF of VCO
Reply #1 - Jan 17th, 2023, 9:19am
Dear subtr,
Do you still have an interest in your question? If so, I can share an Excel workbook that you can use to place your control voltage noise data (noise versus frequency) and it will plot the resulting output phase noise given the Kvco.
Shawn
Shawn
