Jan 13th, 2026, 4:41am
how to set initial state of digital circuit in AMS simulation? (Read 2057 times)
unaffected
Nov 19th, 2021, 12:27am
I am using cadence AMS to do mixed signal simulation(analog circuit + digital circuit(verilog.v)), in digital cicuit, some DFFs used in frequency divider do not have initial reg value, the reg initial value should be set to avoid X state.
Would someone teach me how to set all regs' initial value to 0 or 1?
Many thanks.
Re: how to set initial state of digital circuit in AMS simulation?
Reply #1 - Feb 10th, 2022, 1:46pm
Do you have the DFF model, can you edit it to allow specification of an initial reg value?
