Mar 27th, 2023, 12:22am
voltage regulation (Read 430 times)
zahramoh
voltage regulation
Feb 02nd, 2022, 8:56am
I am designing a digital temperature sensor using a ring VCO. The supply voltage is 1.2V and should be constant without any changes due to noise or other parameters. How can I have this constant supply voltage?
Re: voltage regulation
Reply #1 - Feb 10th, 2022, 1:55pm
Noise will certainly change the voltage, and as the VCO operates, it will pull different amounts of current from the supply, which will cause fluctuations.
I think you probably need to decide how much fluctuation you can tolerate, and then design the voltage regulator (LDO) to do better.
Horror Vacui
Dresden, Germany
Reply #2 - Mar 14th, 2022, 7:42am
You need a regulator with zero ohm output impedance, and/or an infinite capacitance at the supply. Or at least try to achieve a performance which mimics these ideal conditions.
The current fluctuations in your circuit -- if it's a digital ring VCO, there will be current spikes for every transition -- will drop a voltage on the output impedance of your regulator. A regulator typically has a feedback loop and the regulator is effective only within the bandwidth of this loop. At frequencies above that you can combat voltage droops with a low ESR capacitor on your supply. If the cap is small, then charges/current taken from it will drop its voltage. The current from it will drop a voltage through its ESR.
