Jul 5th, 2025, 5:12pm
Supply change in post layout simulation (Read 951 times)
niloun
Feb 11th, 2022, 10:39pm
Hi everyone,
In the very last stage of a  phase generator that I have designed for a TI ADC, I see the following phenomenon. As you can see, supply (Second signal) changes with the input (First signal) in post layout simulation. Phase generator is connected to the SAR ADCs.
Could you please help me understand what is happening?
niloun
Re: Supply change in post layout simulation
Reply #1 - Mar 3rd, 2022, 10:53am
Solved. The extracted file was corrupted! Using dspf extraction solved it. Supply nodes were floating!
Nilou
