Jul 27th, 2024, 5:07am
a behavioral model to measure a SMPS like buck converter's loop (Read 376 times)
RobertD
Oct 31st, 2022, 10:50pm
I am wondering if there is a behavioral model to plot a SMPS like buck converter's loop in transient simulation like below website.
https://www.analog.com/en/technical-articles/ltspice-basic-steps-in-generating-a...
Thanks!
Re: a behavioral model to measure a SMPS like buck converter's loop
Reply #1 - Mar 6th, 2023, 7:58am
The link you shared shows that the simulator in question supports ".fra" as a new analysis type. This is outside the scope of a hardware description language like Verilog-AMS, which does not require a simulator to support specific analysis types.
Probably one could develop a model that would be helpful in generating the plot, but you'd need some extra code, either in the simulator or in a post-processing tool.
