Jul 15th, 2024, 9:44pm
genvar for loop instantiation (Read 506 times)
Shubham_Kumar
Dec 18th, 2022, 8:01pm
While modelling a VCDL need to instantiate 40 delay cells.
Following code gives error during compilation
// VerilogA for DLL_behavioural_vams, vcdl, veriloga
`include "constants.vams"
`include "disciplines.vams"
module vcdl(Phi, CK_in, Vctrl);
input Vctrl, CK_in;
electrical Vctrl, CK_in;
output [39:0] Phi;
electrical [39:0] Phi;
delay_cell dcell0(Phi[0], CK_in, Vctrl);
for(genvar i=1; i<40; i = i+1) begin
     delay_cell dcell(Phi[i], Phi[i-1], Vctrl);
Log file contents :
Reading file:
       /user_data1/mtech/18IE34001/work_umc_180/DLL_behavioural_vams/vcdl/veriloga/ver
iloga.va
Reading file:
       /software/eda/cadence/installed_bds/SPECTRE171/tools.lnx86/spectre/etc/ahdl/con
stants.vams
Reading file:
       /software/eda/cadence/installed_bds/SPECTRE171/tools.lnx86/spectre/etc/ahdl/dis
ciplines.vams
Error found by spectre during AHDL compile.
  ERROR (VACOMP-2259): "for<<--? (genvar i=1; i<40; i = i+1) begin"
       "/user_data1/mtech/18IE34001/work_umc_180/DLL_behavioural_vams/vcdl/veriloga/ve
riloga.va",
       line 15: syntax error.
   ERROR (VACOMP-1814): Maximum allowable errors exceeded. Exiting AHDL
       compilation....
What is possibly going wrong  :-/?
getVersion()
"@(#)$CDS: virtuoso version 6.1.7-64b 12/16/2018 07:36 (sjfhw317) $"
getVersion("virtuoso")
"sub-version  IC6.1.7-64b.500.23 "
jbdavid
Re: genvar for loop instantiation
Reply #1 - Dec 18th, 2022, 10:24pm
The error message is flagging "for" which I think needs to be included inside some form of block, maybe a generate block?
Good luck
jbdavid
Shubham_Kumar
Reply #2 - Dec 18th, 2022, 11:06pm
I added the for in generate ... endgenerate block. Still getting the same error ! Not sure what exactly is the problem...
input Vctrl, CK_in;
output [39:0] Phi;
generate
endgenerate
Reply #3 - Mar 6th, 2023, 7:53am
I don't think Verilog-AMS allows variable declarations inside the for-loop: you need to declare genvar i; beforehand.
genvar i;
for(i=1; i<40; i = i+1) begin
