Sep 15th, 2026, 9:30pm
Direct Conversion Receiver (Read 1901 times)
Marios
Jun 07th, 2023, 6:41am
Dear all,
I am simulating a direct-conversion Rx. It comprises an LNA followed by a passive mixer followed by a "current-input" baseband filter (By current input I mean input stage is transimpedance amp) as shown in Fig A.
Instead of using PSS/PAC/PNOISE to simulate everything, I tried to create an sp-model of the baseband filter using an SP analysis. As shown in Fig B, I run an SP saving all S-parameters along with noise of the filter in the 2-port.
Then I used the 2-port to load the mixer and run PSS/PAC/PNOISE as shown in Fig C. For some reason, I do not get the same results (I mean the difference are some dBs in gain and NF). My fundamental is 2.5GHz and the 2-port contains data up to 20GHz so I guess this is enough for 7th harmonic.
Any ideas of what could I get wrong is much appreciated.
Marios
