Nov 7th, 2026, 9:25am
How to create a verilog-A testbench to run a sweep of all input pins (Read 4361 times)
avlsi
singapore
Aug 02nd, 2023, 5:45pm
I am trying to use verilogA to run functional verification of some sub blocks.
I have created the schematic in such a way that there are 2 symbols
1. DUT - Device Under Test
2. STIM - Stimulus - This contains DUT input pins as output pins and vice versa
I have a bi directional IO to verify in the DUT. I am currently settling each pin voltage as a test case and verifying whether the operation makes sense. I want to do a single testcase without any sweep variables using verilogA to run through combinations and verify the output according to datasheet of the IO for both input and output mode.
Can anyone share a example on how to get it done.
Winners never Quit,Quitters never Win
Re: How to create a verilog-A testbench to run a sweep of all input pins
Reply #1 - Aug 3rd, 2023, 4:48pm
Can you use Verilog-AMS?  It is much better suited for the task.
avlsi
singapore
Reply #2 - Aug 3rd, 2023, 5:36pm
Hi Ken,
I am using spectre as simulator. I am not sure whether it supports verilog ams.
Reply #3 - Aug 3rd, 2023, 10:27pm
It does not.  You would need AMS Designer.
avlsi
singapore
Reply #4 - Aug 4th, 2023, 12:12am
Thanks Ken. I might have limited access to AMS designer. Is there any example to do this verification there?
Reply #5 - Aug 5th, 2023, 11:42am
You can find a conceptual description of the process along with a somewhat incomplete example here: Introduction to Analog Verification.
avlsi
singapore
Reply #6 - Aug 16th, 2023, 3:52am
Hi Ken,
I could try sweeping the pins in the vlogams. I had to do some custom blocks to do d2a and a2d conversions at the boundaries.
for(i=3'b000; i<=3'b111; i=i+1'b1)
 begin
    a = i[2] ;
    b = i[1];
    c = i[0] ;
      // Print the values (for simulation visibility)
    $display("i = %b, a = %b, b = %b, c = %b", i, a, b, c);
    #(10000); // Wait for so much time steps
one thing I am concerned, whether I am doing overkill by sweeping inputs and running a digital simulator instead of analogue simulator for block-level checks.
Is there a better way to use Verilog-A with this #(10000) to sweep input?
Reply #7 - Aug 21st, 2023, 10:43pm
Verilog-AMS is a good skill to have.  And the ability to write testbenches in Verilog-AMS is a particularly useful aspect of that.  I suggest that you think of learning and using Verilog-AMS as an investment.
You can write testbenches in Verilog-A but it is ugly and nobody that knows Verilog-AMS would do so.  Since it is unpopular, I cannot point you to any examples that you could learn from.  There are some things on functional modeling in Verilog-AMS, which is helpful but not the whole story (Functional modeling in Verilog-A).
