Oct 18th, 2024, 2:00am
How to parametrize input bits of a DAC in Verilog A code (Read 306 times)
Andrea8888
Oct 06th, 2023, 1:10am
Hi All,
as written in the subject, in case i want to leave the number of bits as parameter that user can choose in every run without changing the code ..: how to do it?
Which is the syntax to leave inputs / outputs of an istance as parameter?
Thanks in advance for the help
Re: How to parametrize input bits of a DAC in Verilog A code
Reply #1 - Oct 6th, 2023, 10:22am
Take a look at https://designers-guide.org/verilog-ams/functional-blocks/data-converter/convert...
er-lrm.vams
However, be aware that you cannot use such a model in a Cadence schematic.  Schematics do not allow the number of lines in a wire to be variable.
