Oct 16th, 2026, 3:24am
A question on STB analysis of OSC (Read 6924 times)
chang830
Dec 02nd, 2024, 5:07am
Hi , I have  a problem on simulation of xtal oscillator. When I simulatie a Santos xtal OSC, I use STB to get its gainmargin which I found it is -1.5dB.So it should not to oscillate, but I found it can oscillate corectly when I use transisent analysis.  Can anyone explain this descranpcy?
Thanks a lot!
Re: A question on STB analysis of OSC
Reply #1 - Dec 2nd, 2024, 10:39am
Chang,
  Are you using stability analysis or periodic stability analysis?
chang830
Reply #2 - Dec 2nd, 2024, 5:35pm
Dear Sheldon,  I use stability analysis. I think in the beginning of the buildup, it is linear.
