Jitter Man
![](http://www.designers-guide.org/Images/jitterman.gif)
Am I? Or am I so sane that u just blew your mind?
Sorry, I misled you a bit. You should not follow the procedure for extracting jitter of the PFD, which has an analog output, you should follow the procedure for extracting jitter of a frequency divider, a purely digital circuit. This is section 4.1 in the given reference. Notice that it indicates you should integrate the noise density from -f0/2 to f0/2.
