May 6th, 2024, 11:18pm
Pages: 1 2 3
Simulate Phase noise DLL (Read 1004 times)
Nico67
Aug 13th, 2004, 5:21am
Hello, I want to simulate the phase noise of my DLL.
In first, I use the simulation PSS and Pnoise with my VCDL. I obtain a result in dBc/Hz, and with some calculations I obtain the phase noise in ps.
But I don't sure that the result is just because the jitter is approximately 0.15ps. I think that I not use a good transformation for pass dbc/Hz to ps.
If you can explian the calculation for this transformation
Thank
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Re: Simulate Phase noise DLL
Reply #1 - Aug 13th, 2004, 7:39am
To characterize the jitter of a VCDL you would use the same procedure you would for a PFD, which is described in Modeling jitter in PLL-based frequency synthesizers at www.designers-guide.com/Analysis.
Jitter Man
Nico67
Reply #2 - Aug 13th, 2004, 7:54am
Thanks, jitter man
but I have some questions:
I use the method describe in this guide, and I obtain a curve for the phase noise in dBc/Hz.
I have a clock at 62.5MHz and for the simulation, i want to simulate the phase noise of the buffers.
I obtain, for example -165dbC at 100KHz eg 0.001ps that I can't be exact.
1. How choose the value of delta f ?
2.Why don't integrated the curve of the phase noise?
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Reply #3 - Aug 13th, 2004, 10:58am
Sorry, I misled you a bit. You should not follow the procedure for extracting jitter of the PFD, which has an analog output, you should follow the procedure for extracting jitter of a frequency divider, a purely digital circuit. This is section 4.1 in the given reference. Notice that it indicates you should integrate the noise density from -f0/2 to f0/2.
Jitter Man
Nico67
Reply #4 - Aug 16th, 2004, 12:50am
I simulate with Cadence RF Pnoise
In sweeptype I use relative and in Sweep range I use
min 0 max Fo/2 . Are you ok?
Input source none because I want simulate the contribution of noise of the buffers in my VCDL.
In positive output node i use a output of my VCDL.
To this output I see the contribution of all the buffers or just the buffer corresponding to the node?
Nico67
Reply #5 - Aug 17th, 2004, 6:48am
Please I need help to calculate the phase noise in ps.
When I have the curve in dBc/Hz I don't know how to transform this phase noise to ps. In the analisys , you use a c=L(f)*deltaf^2/fo^2 but how choose the value of the deltaf?
Frank Wiedmann
Munich, Germany
Reply #6 - Aug 17th, 2004, 8:35am
You should probably use the strobed noise analysis of SpectreRF. See http://www.designers-guide.com/Analysis/PLLnoise+jitter.pdf, in particular section 9.
Nico67
Reply #7 - Aug 17th, 2004, 10:28am
I have read all the analysis but I don't understand how choose the delta(f) in the formule.
I make the simulation Pnoise and I obtain the curve Phqse Noise dbc/Hz.
In the example of the analysis you explain that you obtain -95dBc at 100KHz. But I don't know that you choos e the 100KHz.
In other analysis they integre the curve from fc to 10MHz, and the result is not the same.
Thanks for your informations
Frank Wiedmann
Munich, Germany
Reply #8 - Aug 17th, 2004, 11:46pm
The rule how to choose delta(f) is given immediately after equation (77) in the paper I mentioned. However, this should not bother you at all because a DLL is not an autonomous system. There is no delta(f) in the equations in section 9.
Nico67
Reply #9 - Aug 18th, 2004, 2:38am
Thank Frank,
The phase noise of the buffers is in the Jitter type synchronous and I need use the period jitter corresponding for a PLL to the PFD.
It is just ?
Frank Wiedmann
Munich, Germany
Reply #10 - Aug 18th, 2004, 4:03am
Use the same procedure as for the divider (as already mentioned by Jitter Man), see section 9.1.1.
Nico67
Reply #11 - Aug 18th, 2004, 6:38am
Ok How determine dv/dt with the PSS simulation ?
Thanls
Frank Wiedmann
Munich, Germany
Reply #12 - Aug 18th, 2004, 6:51am
You can use the calculator functions deriv() to get the derivative and value() to pick the correct tc.
Nico67
Reply #13 - Aug 18th, 2004, 7:32am
But with PSS simulation
I don't have a curve , I have curve with the harmonic range.
Nico67
Reply #14 - Aug 18th, 2004, 7:33am
Ok I have find in sweep I use time and not spectrum
Pages: 1 2 3
