Apr 27th, 2024, 10:26pm
Thermal noise floor in oscillators (Read 942 times)
Lieutenant Columbo
Just one more thing
Oct 01st, 2002, 9:49pm
I am using SpectreRF to find the phase noise of an oscillator. I see the 1/f3 and 1/f2 regions, but I don't see a white noise floor as I would expect. In fact, I don't know that I have ever seen a white noise floor when simulating oscillators with SpectreRF.
Why is that?
Re: Thermal noise floor in oscillators
Reply #1 - Oct 1st, 2002, 10:39pm
In my experience one usually does not see the thermal noise floor because the noise analysis is setup to compute the noise at the resonator. In other words the output of the oscillator is taken at the resonator, and there is no buffer amplifier present. In this case the there is no thermal noise floor because it is shorted out by the resonator. If you add a buffer stage, you will see the thermal noise floor. Designers are use to always seeing the thermal noise floor because high-frequency spectrum analyzers have 50 Ohm inputs, and so there must be a buffer between the resonator and the analyzer.
Lieutenant Columbo
Just one more thing
Reply #2 - Oct 1st, 2002, 10:43pm
But won't the oscillator have a resistive component in its output impedance? Wouldn't the thermal noise from the resistive component create a noise floor?
Reply #3 - Oct 1st, 2002, 10:48pm
Consider a differential LC oscillator. In this case, the output is shunted by a parallel LC resonator. Often the inductor is connected to an ideal voltage source and the capacitor connected to ground. Thus, low frequencies are shorted by the inductor and high frequencies are shorted by the capacitor. If you added a resistance in series with the capacitance to model its finite Q, then you might see a white noise floor, but it will likely be at a very low level, perhaps too low to see. Notice that if you add the resistance in series with the inductance, you would see a noise floor at low frequencies, not at high frequencies.
