May 18th, 2024, 10:13am
Sparse matrix (Read 5686 times)
vova
Sparse matrix
Apr 04th, 2003, 4:00pm
I am using Sparse V1.3a and need to get a pointer to an existing element knowing only row and column numbers. Actually Sparse which I am using does not have a function for that. So I just want to know if
such a function already exist, or I am forced to write my own, modifing spPrint()?
Vova.
Re: Sparse matrix
Reply #1 - Apr 4th, 2003, 4:17pm
The function spGetElement allows you to get a pointer to an existing element knowing only the row and column number. It will, however, create the element if it does not already exist.
vova
Re: Sparse matrix
Reply #2 - Apr 4th, 2003, 5:06pm
I don't want to waste memory. I have a look at spGetElement. It seems I can use spcFindElementinCol() with NO as a last argumen. But I am cunfused, will it work for col=row?
Thanks a lot,
Vova.
Re: Sparse matrix
Reply #3 - Apr 8th, 2003, 3:24pm
There is a function in the Spice3 compatibility code in spSMP.c that does what you want. It is SMPfindElt(). Do you have that code?
vova
Re: Sparse matrix
Reply #4 - Apr 10th, 2003, 1:55pm
Yes, I have spsmp.c. Thanks for letting me know about SMPfindElt(), now I am using this function.
Vova.
rf-design
Reiner Franke
Re: Sparse matrix
Reply #5 - Oct 13th, 2003, 2:06am
I am interessted in circuit simulation implementation.
Does anybody now about
1. Solving sparse matrix by combinations of direct and iterative method. Where pivot ordering and selection generate side information which part to solve direct and which iterative.
2. Is there a reuse of pivot information while processing different transient steps?
3. Does the pivot selection and reordering change much at circuit discontiniousities?
4. Does circuit simulator implementations exist based on state variable approach. How these implement rank deficiencies?
