Sep 30th, 2026, 1:12am
temperature simulation (Read 1580 times)
aceman
Apr 09th, 2003, 2:25am
how can i do temperature simulation in cadence. I designe circuit with temp shutdown, and i need simulate temp hysteresis. Please help me. beginner.
View Profile 220254550   IP Logged
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: temperature simulation
Reply #1 - Apr 9th, 2003, 9:55am
I assume that you want to do a DC simulation in Artist. If so, it's a piece of cake.
Just use the "choose analysis" form to select DC analysis, and push the button to enable sweeping, and select temperature sweep.
To see the hysteresis, you will need to run two analyses. One where you sweep the termperature up, and the other were you sweep it down.
- MM -
