Check your Setup->Environment form, and look at the setting of "Analysis Order". There is a "feature" of the tool where if you don't specify all the analyses that you're running, it doesn't run the rest in the right order. It runs those which you've specified in this form correctly.
My guess is that you don't have pnoise in the list? (I think if I remember rightly, any analyses which aren't in the list are executed in alphabetical order?)..
There is a PCR (556556 for anyone interested) which asks for any analyses not specified in the order to be run in the default order.
For now the workaround is to either leave this field blank in the Setup->Environment form, or to add the analyses in the correct order.
