Mighty Mouse
Here I come to save the day!
Fantasyland
Do you have SpectreRF? If you are designing VCOs you should. Anyway, with SpectreRF it is easy. Simply use PSS analysis to compute the steady-state behavior. By default it computes the magnitude and phase of each signal, so you can simply subtract the phase of the output signals to determine their phase difference.
- MM -
