May 18th, 2024, 3:54pm
How to export data (ploting)?? (Read 56 times)
Aigneryu
Aug 12th, 2003, 12:35am
Hi!
Recently I need to export Spectre simulation results such as signal spectrum or waveform for further process.
I can use ideal sampler included in the standard ahdl lib to export time domain waveform. However, I do not know how to export frequency data from certain simulation bench such as PSS or PNoise or even PSS waveform.
Does anybody know how to export these data in two dimensional format just as the waveform or spectrum plot??
Vladimir Fomin
Guest
Re: How to export data (ploting)??
Reply #1 - Jan 7th, 2004, 12:41am
Using "print" button of calculator you can print any waveform with any step into a file. Then you can import this data into another tool.
  IP Logged
