Do you have the LDV stream (<ldvInstdir>/tools/bin) in your UNIX path?
Or are you referring to the full path to the executable?
Are you using the NC-Verilog integration, or are you using AMS Designer?
I'd certainly make sure that you have the software in the path - that would explain the can't determine installation root from path error. Not sure about the segmentation fault though.
Which versions are you using (icfb -W, ncsim -version)?
