May 8th, 2024, 9:51pm
LC VCO Simulation using SPECTRE (Read 3900 times)
junkwar2003
WA
Jan 13th, 2004, 5:21pm
I am trying to run a standard CMOS LC VCO [cross-coupled Tank LC VCO] simulation in SPECTRE.
I am using TSMC25u provided Inductors and Varacters and such, basically all real elements.
I cannot get the circuit to oscillate. I read that in spectre you need to provide a start up to get
the oscillation going. I have tried injecting ipulse, vpulse, psin source in the output node of the
oscillator to get to start switching but still no luck. I was wondering if anyone know a magic trick
to run LC VCO simulation in SPECTRE. Any hints would be helpful. Thanks
-Parag
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: LC VCO Simulation using SPECTRE
Reply #1 - Jan 13th, 2004, 10:46pm
The need to kick-start oscillators is not unique to Spectre, it is necessary with all simulators. There are two basic approaches that can be used, you can either apply initial conditions to one or both of the resonator components, or you can inject a transient signal into the resonator. With LC oscillators, I would recommend injecting a sinusoidal current into the resonator with a damping factor. Ken has a section in his book on this.
- MM -
junkwar2003
WA
Reply #2 - Jan 16th, 2004, 5:54pm
I got the ossc. to start using ipulse but thanks for your response.
Parag
