Apr 30th, 2024, 2:39pm
hsim vs nanosim vs mach vs ultrasim vs starsimXT (Read 6073 times)
okguy
Feb 09th, 2004, 5:46am
Which one is fastest ? I read hsim is the best, but mainly for memory. How to compare ? Any ideas ?
sim
Re: hsim vs nanosim vs mach vs ultrasim vs starsim
Reply #1 - Mar 9th, 2004, 1:57am
i can't tell you which one is the fastest.
but i think hsim is more compatible with hspice,it take you less time to use.
if you design envirment is Cadence ,you can choose hsim
and ultralsim , they all support mixmode simulation with ncsim
nanosim support mixmode simulation with VCS
I commend hsim,it is easy to use and maybe the fastest
simulator.
VincentLee
Reply #2 - Jan 10th, 2005, 4:50am
[quote author=okguy  link=1076334385/0#0 date=1076334385]Which one is fastest ? I read hsim is the best, but mainly for memory. How to compare ? Any ideas ? [/quote]
UltraSim can also support the Hspice netlist format. And it has embeded in the Analog Design Environment in Cadence.
So I think UltraSim is your best choice.
Vincent
try my best...
