Sometimes I have the following error when trying to create netlist and start simulation in Affirma Analog Circuit Enviroment:
*Error* fprintf/sprintf: format spec. incompatible with data
After that netlist is not created, Spectre is not starting etc.. I am using Cadence 4.4.6. The problem is that this error appears more or less randomly - when you start a new design it can appear or not, but once Spectre started wveruthing is ok - I can modify things and simulate further on.. Similarly - once it has appeared, I can't do anything
![Sad Sad](https://designers-guide.org/forum/Templates/Forum/default/sad.gif)
Has anyone met with similar things? ???
