Apr 25th, 2024, 10:55pm
Simulation error in Cadence (Read 46 times)
boa
Feb 18th, 2004, 4:48am
Sometimes I have the following error when trying to create netlist and start simulation in Affirma Analog Circuit Enviroment:
*Error* fprintf/sprintf: format spec. incompatible with data
After that netlist is not created, Spectre is not starting etc.. I am using Cadence 4.4.6. The problem is that this error appears more or less randomly - when you start a new design it can appear or not, but once Spectre started wveruthing is ok - I can modify things and simulate further on.. Similarly - once it has appeared, I can't do anything Sad
Has anyone met with similar things?  ???
