Jimmy,
Why would you expect to see a speedup? It's the same simulator, so unless the fact you're running out of memory by having DFII/ADE running at the same time, or you are doing something else compute intensive in ADE, I'd not expect it to be any slower, really.
(unless you're talking about the "spectreS" interface, because that could slow things down a lot because it was spending so much time printing information into the CIW and the top of the ADE window and the schematic window). With the "spectre" interface, there's minimal overhead in running via ADE.
