Feb 7th, 2026, 8:29am
How to simulate noise using Spectre/SpectreRF (Read 4218 times)
ayow
Guest
Mar 28th, 2004, 9:04pm
I would like to simulate noise curve of a MOSFET.
The noise curve should with freq. swept from 0~30MHz
to include 1/f , thermal and shot noise.
Which analysis I can use ? Could you please provide the
example of input.scs ?
Thanks.
Ayow ???
  IP Logged
Re: How to simulate noise using Spectre/SpectreRF
Reply #1 - Mar 29th, 2004, 6:13am
Here's a simple example - just put this together for one of my colleagues:
// Generated for: spectre
// Generated on: Mar 29 11:31:59 2004
// Design library name: mynoise
// Design cell name: test
simulator lang=spectre
global 0
parameters vg=1 vd=2
include "rfModels.scs"
// Library name: mynoise
// Cell name: test
// View name: schematic
V1 (net1 0) vsource dc=vd type=dc
V0 (net3 0) vsource dc=vg type=dc
M0 (net1 net3 0 net1) nmos301 w=10u l=1u
    digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
    sensfile="../psf/sens.output"
noise noise start=1 stop=1G dec=10 oprobe=V1 annotate=status
The rfModels.scs is:
// rf models
model nmos301 mos3  type=n   \
 vto=0.725  uo=585.0  tox=23.5n  nsub=3.27e+16 \
 nfs=3.5e+11  vmax=1.6e+05  eta=0.012  kappa=0.13  theta=0.080 \
 delta=2.62  xj=0.08u    rsh=533.0 \
 ld=0.250u  cgdo=2.1e-10  cgso=2.1e-10  af=1.0  kf=2.5e-28 \
 cj=4.4e-04  mj=0.370  cjsw=3.4e-10  mjsw=0.220  pb=1.100
Note that the models themselves need to have flicker noise enabled (the above simple mos3 model does, because it has af, kf defined).
Essentially you can wire up the device how you want; I'm measuring the noise through id in the V1 voltage source. Because I'm measuring it with a probe of a voltage source, the output will be in A/sqrt(Hz) (or A**2/Hz).
