Sep 17th, 2024, 2:31am
Question regarding track and hold model (Read 4070 times)
gmande
May 03rd, 2004, 2:01pm
Hello Experts,
I have a question regarding track and hold model explained in "Hidden State in SpectreRF" document. Please refer to Section 4, Figure 1 and Listing 2. In listing 2, the veilogA model th contains an internal node hold. V(hold) has been used inside the code. But I am not able to understand where and how the V(hold) value is getting eavaluated.
Please let me know if you need more information.
Thanks and Regards,
Geeta...
Re: Question regarding track and hold model
Reply #1 - May 3rd, 2004, 2:45pm
Isn't it fairly clear:
// Implement switch with effective series resistence of 1 Ohm
if (($abstime > tstop – aperture) && ($abstime <= tstop))
  I(hold) <+ V(hold) – V(Pin, Nin);
else
  I(hold) <+ 1.0e–12 * V(hold);
// Implement capacitor with an effective capacitance of tc
I(hold) <+ tc * ddt(V(hold));
// Buffer output
V(Pout, Nout) <+ V(hold);
The first bit is a switch, which is either a 1 ohm series resistor,
or a leakage resistance of 1 teraohm to ground.
The second is the equation for a capacitor.
And finally V(hold) is used.
With Verilog-A you can write the relationship between currents and voltages - you don't always have to formulate the equation so that the voltage is assigned to.
For example, a resistor can be defined as:
I(plus,minus) <+ V(plus,minus)/R;
just as well as:
V(plus,minus) <+ I(plus,minus)*R;
both forms are effectively equivalent.
So do you understand now? If not, can you elaborate on what it is you don't understand?
gmande
Reply #2 - May 4th, 2004, 1:03pm
Hello Andrew,
Thank you so much.
Geeta...
Eugene
Reply #3 - May 4th, 2004, 7:34pm
You can also use a resettable integrator that integrates zero. Set the integrate indentically to zero. Insert the input you want to track and hold into the integrator's initial condition. When the integrator's assert input is nonzero, the integrator tracks the time varying initial condition. When the assert input drops to zero, the integrator holds the initial condition. I have used this successfully with SpectreRF.
