Jul 21st, 2024, 6:16pm
VCO output impedance measurement. (Read 3642 times)
wccheng
May 04th, 2004, 11:11pm
Dear all,
   Could I use the s-parameter machine to measure the VCO output impedance?
   As we provide the Vdd to the VCO, it will generate the frequency with the output power. If I use the s-parameter to measure the output impedance, is the result corret and will it destroy the s-parameter machine?
Charles CHENG
mobil
Australia
Re: VCO output impedance measurement.
Reply #1 - Aug 22nd, 2007, 6:15pm
I think u can estimate the oscillate point by this method, but the final results should be read from spectre anaylzer to see whether it's oscillating
