Aug 16th, 2024, 2:48pm
VCO Duty Cycle (Read 3089 times)
bhupendra
Guest
VCO Duty Cycle
May 26th, 2004, 5:56am
we're working on 400 MHz VCO Design. We've used current starved type VCO. This works fine and gives proper duty cycle with all corner cases except FF 0 3.7V
and FF 85 3.7V. Its duty cycle is varying. So how can we proceed with this issue.
  IP Logged
neoflash
Mixed-Signal
Designer
Re: VCO Duty Cycle
Reply #1 - Nov 11th, 2005, 6:57am
Can you put the schematic?
juddy
Re: VCO Duty Cycle
Reply #2 - Dec 3rd, 2005, 7:47am
Have you check DC operation points at your refered cornner?
