Jul 24th, 2024, 8:30am
Spectre netlist -> Hspice netlist method (Read 2427 times)
wccheng
Jun 01st, 2004, 10:51pm
Dear all,
I want to convert the spectre netlist to hspice netlist. How could I do it? Due to the license problem, I could not directly generate the hspice netlist directly. It could generate the spectre netlist instead. However, I need to have a hspice netlist. Therefore, is any method to convert the spectre netlist to hspice netlist?
Thanks for your helping
wccheng
Re: Spectre netlist -> Hspice netlist method
Reply #1 - Jun 2nd, 2004, 3:55am
Write yourself a perl script? Spectre has fairly regular syntax, so
it should be easy enough to write a script to convert 99% of the
netlist to hspice format.
I'm assuming that you have spectre, since you can netlist
for spectre - is there a reason why you need to use hspice
for simulation instead of spectre?
