Jul 2nd, 2025, 9:32pm
how to measure phase margin in real chip? (Read 6554 times)
vlado
Guest
Jun 04th, 2004, 1:10am
Hi, I need to measure phase margin in real chip. It is low drop out regulator and i need to know how stable is that circuit. Open loop measurement isn`t so exact, i thing...
thanx
  IP Logged
Frank Wiedmann
Munich, Germany
Re: how to measure phase margin in real chip?
Reply #1 - Jun 4th, 2004, 4:20am
Do you mean measurement in the lab or simulation? If you mean simulation: Spectre 5.0 has a stability analysis (stb) that keeps the loop closed. If you mean measurement in the lab: take a look at http://www.venable.biz/tr-papers2.html.
vlado
Guest
Reply #2 - Jun 7th, 2004, 2:11am
i mean real measurement in lab, SPICE simulation is quit simple, but in real it is problem.
  IP Logged
Reply #3 - Dec 28th, 2004, 6:08pm
Vlado,
  Never measured phase margin on the bench so it is a good question. Have you tried putting in a small square wave, need to avoid slew rate limiting, and looking at the overshoot? You should be able to infer phase margin from small signal overshoot. Don't remeber the formula for conversion, it is in most textbooks, Gray and Meyer and Allen.
        Art Schaldenbrand
