May 1st, 2024, 4:20pm
montecarlo modelling example!! (Read 1120 times)
nano_RF
madison
Jun 15th, 2004, 10:35pm
Hello Ken,
In your article you have talked about some spread (sigma). Is it the variance or mean value?
Also when you define gaussian distribution to a process parameter,is this the variance or mean value(distribution)?
All this correlation coefficient and parameter variation are known to only foundary people,So do they provide it with the model file ?
--Vikas
Re: montecarlo modelling example!!
Reply #1 - Jun 16th, 2004, 2:38pm
I assume you're talking about Don O'Riordan's note
http://www.designers-guide.com/Modeling/montecarlo.pdf?
If so, sigma is standard deviation. Process distributions consist of both a mean value and a standard deviation of course.
I'm not really sure what (if anything) you're asking.
In general, this information needs to be provided by the process foundry. Ideally they would provide statistics blocks with the model files, but it doesn't always happen...
Reply #2 - Jun 16th, 2004, 2:38pm
Reply #3 - Jun 16th, 2004, 2:39pm
Apologies for the double post - I got a server error part way through posting, and re-posted before I checked to see if it had posted already  :'(
nano_RF
madison
Reply #4 - Jun 17th, 2004, 9:36am
Thanks Andrew,yes it is Don's article not Ken's.
I would like some more clarification of your reply to topic
"monte carlo mismatch simulation in spectre "@
http://www.designers-guide.com/Forum/?board=circuit;action=display;num=107480475...
Here i am facing the same problem(no mismatch variation) and i do'nt really understand  "surrounding the parameterized model".
Can you please  put more light on this?
--Vikas
Reply #5 - Jun 21st, 2004, 3:54pm
Hi Vikas,
This is quite clearly outlined in Don's paper. You need to make sure you have something like this:
inline subckt mynmos d g s b
parameters w=1u l=1u ad as pd ps ...
mynmos (d g s b) mynmosMod w=w l=l ad=ad ...
// parameterised model
model mynmosMod bsim3v3 type=n param1=value1 param2=value3 ...
ends mynmos
The idea is that you presumably have some parameterised model, with a statistics block describing the std deviation and distribution type of the parameters referred to in the model. What you then do is surround this with a subckt definition (it doesn't have to be inline; that just helps with backannotation), and then you can use the "model" mynmos wherever you like, as if it were a model. Because the real model (mynmosInt) is a parameterised model within a subckt, each instance has its own model, and so they will not be shared. If all instances are shared, you can't have mismatch - whereas if all models are unique to the instance, they can have mismatch.
Does that help?
